no internet connection since two days
  • June 26, 2021
  • 66 keer bekeken
Hello,
since 2 days, there’s no internet connection on my modem.
Light is blinking green, tried to reset, to restart, but still no connection.
On my profile page, it is stated that my IP address can’t be retrieved as modem is offline…
Can you please help?
thanks
Beste antwoord door Ray_mond
Hi @MICHAUT
Call 0800-0402. This number has no charge and is from the KPN helpdesk.
7 reacties
Ray_mond
Forum|alt.badge.img+5
  • June 26, 2021
Hi @MICHAUT
Hi @MICHAUT .  Like @Ray_mond  said: calling 0800 0402 is the best thing you can do now.  You will get instant help with your issue.
  • June 26, 2021
Hello,
thanks for your prompt reply. I’ll call them very soon .
Maja van KPN
Did our helpdesk fix your problem @MICHAUT?
  • June 27, 2021
Will see, a new box will arrive on Monday, hope this will work
Maja van KPN
Fingers crossed @MICHAUT! Will you let us know if everything is ok again with the new Experia Bpx?
  • June 28, 2021
hello, all is good now with the new box, thanks
