No internet connection with my wifi
  • October 2, 2022
  • 72 keer bekeken
Hi, I reported a moving from address1 to address2 before , and then I make a call and canceled the movement. So the Internet should stay at my previous apartment.(address1), But now I found my wifi is not working anymore( connected but no Internet), how can I solve this problem?
Hi @Keyan, welcome.
I understad you movirng order is cancelled so the internet shoud be working at your normal adress. But it doesn't. :(
Only the wifi is not working? Or no connection at all? Have you reset your modem? Still nothing, please call 0800-0402. My colleague will measure your line and take action if needed.
If you prefer help via here. Please fill in your profile and let me know when you did.
2 reacties
  • October 4, 2022
Still no network, maybe there should some technique inspection at my room.
Bart van KPN
  • October 5, 2022
Hi @Keyan, welcome.
