No KPN Connection in my house. Coax does not fit on WAN
  • February 26, 2022
  • 14 reacties
  • 553 keer bekeken
Hello the outlet socket that i have its  different than the modem what I received today , before i had ziggo and the connectors from the main and in the house same like the photo how should i connect the kpn modem box 12, does someone from kpn should change the outlet port ? Please help br,stepan
*admin: topic afgesplitst
Hi @Stepankpn, welcome to our forum! I've taken a look at your adress and according to my information there's no copper connection either so we'll have to wait until they finish installing the fiber connection. However as Ward already mentioned this probably won't be before May.
14 reacties
Forum|alt.badge.img+12
  • KPN Netwerk
  • February 26, 2022
That outlet is for coax only (Ziggo). KPN uses DSL of Fiber. You need to find the outlet for that.
Check this page for pictures of what it can look like (tap on "dsl aansluiting" or "glasvezel aansluiting" to see the pictures)
  • February 26, 2022
If i connect directly this coax  to ethernet it will work or i need an adapter ? Thanks in advance.
Forum|alt.badge.img+3
  • February 26, 2022
you cannot use ziggo connections for kpn period.
if you dont know how or where the kpn connection is. you need a mechanic.
https://www.robkalmeijer.nl/techniek/telecom/huisinstallaties_analoog/index.html
  • KPN Netwerk
  • February 26, 2022
Your KPN signal does not come from that coax outlet. It is that simple.. Search for the other outlet in your home...
  • February 26, 2022
Hi Darkie en Ward i checked my meter kast and there is no kpn connector only ziggo was installed. And i don't know if this connectors are from kpn but its outside of the apartment. Should i contact kpn mechanic to check and install? Thank you for the help.
  • February 26, 2022
And all the outlets at home are coax
  • KPN Netwerk
  • February 26, 2022
It looks like you have a fiber connection which has yet tot be finished (inside the house). One of the cables outside your house is for you. Normally, you should have been contacted by a subcontractor for KPN. Did you miss any calls?
A KPN webcare employee can help you. Wait for a day before someone from Webcare is able to respond in this topic
  • February 26, 2022
No Ward i didn't receive any call from kpn only today the modem came and its written that 1 march i can install it...
  • KPN Netwerk
  • February 26, 2022
Oke.. it is not yet 1 march. But seriously: I checked the postal code on that cable. Most of the houses in that street are not yet connected and are planned for connection in the first week of may.
  • February 26, 2022
May Jesus then why when i applied it was written available my address 1 March that i can start to install...i hope not  may, i don't want to stay without Internet 2-3 months
  • KPN Netwerk
  • February 26, 2022
Please wait for Webcare. Since your house does not seem to be very new, a copper connection should be there. Maybe that is an option.
Is that your postal code on that cable on the foto? And your housenumber?
  • February 26, 2022
*admin: moved private information to profile.
Thomas van KPN
  • February 28, 2022
  • February 28, 2022
Hi Thomas i called kpn today and they told me that they had delay for installation which suppose to be installed 1 march so it will be may the installation.
But its better to be corrected online when people are applying for new internet provider it should be correct date of installation and if they have delay they should contact the customer... thank you for your reply. BR,stepan
