Not able to connect to Mi Box S via 5Ghz (v10a)
  • August 12, 2022
  • 102 keer bekeken
Hello,
Since couple of days, I am not able to connect to 5GHz wifi interface, even though my device (Mi Box S) supports both 2.4GHz and 5GHz connections.
I have Experia Box v10A model with two superwifi in each floor.
Please help me if you know any setting or work around that can solve this issue, so that my Android box Mi Box S 4k always connects to 5GHz for faster streaming.
Thanks in advance.
Beste antwoord door Anonymous
Hello @gpf
Unfortunately I can't find any decent manual for that device.
Maybe a workaround could be to switch off both SuperWifi and let it connect to the Experiabox V10A.
If that is succesfull then you can switch on the SuperWifi's again.
2 reacties
  • August 13, 2022
Hello @gpf
Thomas van KPN
Hi @gpf, welcome to our forum!
I don't have any info on your device either. Did you try the workaround GeSp mentions?
