Surface Pro 8 can't connect KPN Box 12's Wifi
  • March 14, 2023
  • 54 keer bekeken
As topic my laptop surface pro8 can’t connect wifi box12. I try to renew the 5G band in mymodem.kpn but my password didn’t work. I try several times used default password on the sticker from the back of the Box. Do you have any good solution to fix it and reset the password to me.
Thanks,
Joe
Beste antwoord door Anonymous
Hello @Joe Huang
Try if this links works to login: https://192.168.2.254/2.0/gui/#/login
If it still doesn't work try a browser like Firefox or Safari.
If that also doesn't work you can reset the Box 12 by pushing the reset button for 5 to 15 seconds until the Powerled changes to red color.
Does the Surface have an Intel AX200/201 WiFi card?
Then try if changing the Bandwidth to 80MHz helps, see also this page: https://www.kpn.com/service/actuele-wifiproblemen.htm
2 reacties
  • March 14, 2023
Hello @Joe Huang
  • March 15, 2023
Thanks, your solution is work.
