Upgraded from 50mbps to 200mbps but still old speed.
  • November 5, 2022
  • 68 keer bekeken
Above is a test while connected to WIFI. As you can see from the image above, it doesn’t even reach 100mbps. Sometimes it’s even lower than 50mbps.
Following is instead a speed test on Ethernet. Still it doesn’t reach 100mbps
My router is an Experia v10a. I connect the router directly to the laptop, and same for wifi, they connect directly to the router.
My UTP cable is CAT 6; maximum speed at my address is 200mbps; i have already reset my router through the admin board.
What could it be?
Thank you
2 reacties
  • November 5, 2022
updated with extra info
Forum|alt.badge.img+27
  • November 8, 2022
Hi @shaunyl, welcome on our forum.
Sorry to hear the update hasn't been processed. Do you have a fiberglass connection? If so, would you please power down the fiber unit for about 30 seconds?
