V10a Wifi interfaces restarts every 2 days at 3 AM
  • August 18, 2021
  • 18 reacties
  • 276 keer bekeken
Since the last update, the experia v10A is resetting the wifi interfaces every 2 days, at night, 3 AM.
This means that every wifi connection is dropped. We can see it in the system logs:
Aug 18 03:00:48 VRV9517 daemon.err wlan_monitor[4666]: start_monitor:[213] V10A is working for more than 2 days.
Aug 18 03:00:48 VRV9517 daemon.err wlan_monitor[4666]: start_monitor:[229] Restart wifi interfaces.
Aug 16 03:00:24 VRV9517 daemon.err wlan_monitor[4666]: start_monitor:[213] V10A is working for more than 2 days.
Aug 16 03:00:24 VRV9517 daemon.err wlan_monitor[4666]: start_monitor:[229] Restart wifi interfaces.
Aug 14 03:00:46 VRV9517 daemon.err wlan_monitor[4666]: start_monitor:[213] V10A is working for more than 2 days.
Aug 14 03:00:46 VRV9517 daemon.err wlan_monitor[4666]: start_monitor:[229] Restart wifi interfaces.
Why is that?
I do not think it is a smart thing to drop every customer connection every 2 days. This is affecting us, even if it is done during the night. We need a stable connection for most of the time, and dropping ALL the connection every 2 days is not the way to have it.
Can you please revert back this behaviour?
I heard you've had contact. And if I'm right, the next firmwareupdate will fix it.
18 reacties
Bart van KPN
  • August 20, 2021
Hi @SuperMario86, welcome here.
I haven't heard this one before, but it's quite weird the wifi restarts every 2 days. Have you already reset your modem? Does it solve the problem?
  • August 20, 2021
Thanks for your message, this might explain a lot.
There are many other people that complain about the fact that since the latest firmware update every morning their Sonos equipment lost connection and that they have to restart their V10a to regain connection.
  • August 20, 2021
Honestly, I would like to avoid reset the modem as I have a lot of things configured (restoring a saved config might also reintroduce a problem).
As I see in the logs, it seems to be like a scheduled restart of the interfaces after 2 days of uptime, it doesn't seem a restart due to an error or config issue.
  • August 20, 2021
I totally agree, you should be able to run a router 24x7 without te need to restart it.
It seems that this reset of the wifi interfaces is indeed a scheduled restart and then the question is ... why? Is this a workaround to avoid the V10a crashing due to a memory leak in the wifi functionality?
Ik hope KPN can/will explain this behaviour.
Bart van KPN
  • August 23, 2021
I will notify the engineers. Let's see what they say about the restarts.
  • August 23, 2021
Thank you, please let us know!
Bart van KPN
  • August 23, 2021
I will.
  • September 26, 2021
Any news? It keeps doing this
  • September 29, 2021
I will ask @Bart_Z when he is back from vacation.  For now there is no new information, I'm sad to say.
Bart van KPN
  • October 4, 2021
I asked for an update. Hopefully soon we get more information.
  • October 25, 2021
Any updates? I still have disconnections in the night
Bart van KPN
  • October 26, 2021
Unfortunately not yet.
  • January 4, 2022
Still no news? This issue is there for months, and it is still happening.
Bart van KPN
  • January 5, 2022
No sorry. I notified my colleagues again.
Bart van KPN
  • January 10, 2022
  • January 10, 2022
Hello,
yes I had contact!
Explanation is that every 2 days, the router performs a scan to choose the best wifi channel, thus all the wifi connection must be dropped.
Although, I had selected a manual channel, so it is quite strange that the scan is performed anyway.
In the next release, there will be an option to disable the scan.
Thanks!
Bart van KPN
  • January 11, 2022
Alright, thanks for the explanation.
  • January 11, 2022
It is nonsense that all the connections must be dropped in order to perform a wifi scan. Wifi should stay connect 24x7 and if not it should be corrected bij the supplier of the device (KPN in this case).
Per example, my wifi security camera's are online since the last reboot of my router six month ago and that is how it should be.
