wachtwoord webinterface V8 modem
  • February 13, 2021
  • 9 reacties
  • 156 keer bekeken
Hello,
I am trying to log into the http://192.168.2.254/ however my experia box is version 8 and therefore has no password as on the V10.
Can you please advise on how to obtain the password?
Thanks,
May
Beste antwoord door Bart_2020
Hello @MayG ,
I see from the screenshot that you sent the firmware version is 02.00.141W4. That version is a Telfort one.
This version is different than from KPN Experia Box V8. The initial password is than 1234 instead of blank.
Cheers Bart
9 reacties
RBxx
  • February 13, 2021
Hi @MayG the first time you log on to the Experia Box v8 you leave the password field empty. You will then be prompted to enter your own chosen password.
  • February 13, 2021
Hi @RBxx ,
Thanks for your answer. It is not the first time I have logged in. Last time was a few years back. Don’t remember the password but there is no option to reset. The login ID is Admin.
RBxx
  • February 13, 2021
Hi @MayG the reset button is hidden behind the pinhole at the back marked 'reset'. Press this button a couple of seconds until the power light turns red, then release.
  • February 13, 2021
Hi @RBxx I have done that. Now I am again at the same screen where I see the below:
RBxx
  • February 13, 2021
That’s strange @MayG . After a succesfull reset this should work. I can only assume the reset wasn’t properly completed. Did you press and hold the reset button long enough? Did all the lights go out?
If this doesn’t work I’m out of ideas.
Bart_2020
  • February 13, 2021
Hello @MayG ,
Cheers Bart
RBxx
  • February 13, 2021
@Bart_2020 , well spotted !!
  • February 14, 2021
@RBxx Thanks for taking the time to support me with answers!
@Bart_2020 Indeed well spotted. Password has worked and I am in.
Thank you both for your help with this :slight_smile:
RBxx
  • February 14, 2021
You're welcome @MayG , glad to be able to helpÂ
