Why is the guest network on Box 12 so slow?
  • April 21, 2024
  • 1 reactie
  • 92 keer bekeken
KPN decided to limit Guest Wifi to 10Mbps and not allowing you to adjust it. People are complaining about it since at least 2 years and KPN doesn’t care. Even some people like me spent checking all settings, factory reset etc. spending hours maybe but KPN still doesn’t care about any user experience yet it’s the most expensive ISP in the Netherlands. Next time I won’t choose KPN.
Advice to KPN: At least put a note or warning in the Thuis app next to the Guest network that you have the unadjustable 10Mbps limit so that people don’t waste their valuable hours and get less pissed off.
Reference topic KPN decided to ignore and close:
Beste antwoord door Anonymous
Hello @N D
KPN didn't ignore it, there finally is a new firmware version for the Box 12 (which they are very slowly rolling out) in which you can choose some values between 10 and 50Mbit/s or unlimited for Guest Wifi.
See this artikel:
You can also follow the updates for the modem/routers here: Product Updates
When you will receive the update also depends on whether you have extra KPN Wifi AP's.
So far, only the Superwifi 2 AP’s are supported with the new firmware, so if you got other KPN Wifi AP's you’ll have to wait until they also support them.
1 reactie
  • April 22, 2024
Hello @N D
See this artikel:
