Since ages, Arte has been available in German language on Dutch TV. However, in other countries, the channel is also available in French, and in the past, KPN did provide a smart option to switch languages on its interactive TV.
It is a petty that this option has been removed.
I wonder if KPN could re-activate the possibility to switch again from German to French? It would certainly raise the satisfaction of TV fans of both languages.
Groetjes
Bladzijde 1 / 1
The option was never available.
Dual language is not supported in the IPTV system. Only in the DVB-C system. KPN cannot use DVB-C, only IPTV. Therefor it is not possible to use the two languages. Because Dutch people are much better in German than in French KPN chose to distribute in German.
Until 2 years ago there was an unofficial trick to switch to French (only live). Due to introducing the switching possibility stereo/dolby that trick does not work anymore.
After pausing a live transmission it was French. That was not ment to be.
With satellite transission (DVB norm) you can receive it in French. For free, without supscription for a satelliteprovider.
Thank you PeterG for your reply. Good to know that KPN customers may have to adapt a satellite antenna if they wish to receive Arte in French.
Or switch to Ziggo.
With hybrid reception, KPN + FTA satelite, you have 100's of stations for the same monthly costs.
FTA = stations without subscription
Welcome here Artefan! I think Peters explains it well. We get this suggestion regularly and this feature has been on the backlog for a long period. Unfortunately it doesn't seem to have a lot of priority. I hope that we will make this possible some day but it might still take a while.
