How to activate Teletekst page 888
  • April 10, 2021
  • 254 keer bekeken
alrey31
Helper
Hi, i’ve been searching this. May i know how to activate teletekst page 888 please? I pressed 888 but it went to a radio station.
Dank je
*Admin: eigen topic voor je vraag aangemaakt
Beste antwoord door Piet van der Vooren
Hi @alrey31,
On the Samsung-remote you'll find the teletext-button (TTX/MIX) below the 7-button.
On the KPN-remote you'll find the teletext-button below the 9-button.
I guess you will have to use the KPN-remote to get teletext-page 888 (subtitles) on your tv.
All other teletext-pages are now also available on your tv, not just teletext-page 888. To return from teletext to normal tv-watching, simply press the teletext-button again or the Terug-button on the KPN-remote.
Let me know if this helped!
Piet.
Piet van der Vooren
Hi @alrey31,
Before you press the 888-buttons you have to press the teletext-button on your remote, followed by the 888-buttons.
Piet.
alrey31
Helper
  • April 11, 2021
Thanks for your reply Piet.
Pardon my ignorance, but could you tell me which button is the teletext button? Below is the photo of jy remote control. I tried most of the buttons, but obviously I’m not able to figure it out.
dank je.
Piet van der Vooren
Hi @alrey31,
Piet.
alrey31
Helper
  • April 11, 2021
heel erg bedankt!  It works. I hope this will improve my Dutch! 🤪😅
Piet van der Vooren
@alrey31 Subtitles are a.o. also available on VRT (Belgium), ARD (Germany; page 150), ZDF (Germany; page 777) and BBC (page 888).
Good luck!
Piet.
