KPN TV+ Probleem multicast bij gebruik van een switch
  • January 20, 2024
  • 10 reacties
  • 527 keer bekeken
Ik kan de tv+ box in multicast zetten alleen  rechtstreeks via de kpn 12 box  en niet via de switch box die wel igmp snooping ondersteund.
De switchbox hangt aan de netgear orbi 520
wie weet de oplossing
Beste antwoord door PeterG
Dan moet de wifi mesh van Netgear orbi ook IGMP Snooping ondersteunen en bovendien ​​​​​​, omdat het wifi is, "multicast to unicast".
10 reacties
  • January 20, 2024
Forum|alt.badge.img+12
  • January 20, 2024
@Harmen65 Een Orbi 520 bestaat niet, maar in een Orbi Router moet je de optie "Disable IGMP Proxying” deactiveren.
  • January 20, 2024
Sorry het is de rbr 50
  • January 20, 2024
@Harmen65
View or change WAN settings
Disable IGMP Proxying. IGMP proxying allows a computer on the local area
network (LAN) to receive the multicast traffic it is interested in from the Internet.
If you do not need this feature, select this check box to disable it.
Enable British Telecom IGMP proxy support
You must use this feature only for British Telecom (BT) Internet Protocol television (IPTV)
service. It might also work with TalkTalk IPTV service.
To enable BT IGMP proxy support:
  1. Launch a web browser from a computer or mobile device that is connected to your
    Orbi network.
  2. Enter orbilogin.com. A login window opens.
  3. Enter the Orbi admin user name and password.
    The user name is admin. The password is the one that you specified the first time
    that you logged in. The user name and password are case-sensitive.
    The BASIC Home page displays.
  4. Select ADVANCED > Setup > WAN Setup.
    The WAN Setup page displays.
  5. Clear the Disable IGMP Proxying check box.
  6. Select the Support British Telecom (BT) IGMP Proxying check box.
  7. Click the Apply button.
Your settings are saved.
  • January 21, 2024
Bij de rbr 50 kun je igmp niet instellen
  • January 21, 2024
Dan gaat multicast in combinatie daarmee dus niet werken.
  • January 21, 2024
Ik heb hem nu rechtstreeks via modem kpn dat werkt wel
Of moet ik allemaal andere switchboxen aanschaffen die wel multicast ondersteunen
  • January 21, 2024
@Harmen65 Ben je zeker? Heb je in WAN-instelling gekeken? Volgens Netgear wel sinds versie 1.5.0.12
NETGEAR Support RBR50 / RBS50 Firmware Version 1.5.0.12
New Features and Enhancements:
  • Supports VLAN and bridging on the Orbi router.
  • Supports IGMP proxy.
  • Allows users to enable or disable the “Allow guests to see each other and access my local network”  feature in AP mode.
  • January 21, 2024
Is het dan bezwaarlijk als het zo blijft? Overigens zou ie ook via de wifi van de Box12 kunnen met multicast.
  • January 22, 2024
Nee Peter dat is geen bezwaar
