Remote Control does not seem to store TV code correctly for Panasonic TV
  • May 20, 2022
  • 65 keer bekeken
Sorry for asking in English and short sentences, hope it's understandable.
TV brand: Panasonic
Instruction page: https://www.kpn.com/televisie/installeren/afstandsbediening/instellen.htm
Tried with the first shown remote control on that page.
Used the quick code 5 and found a code the TV works with (on/off, volume).
After confirming with OK button the red light blinked 2x like described but after that only on/off for TV works but no volume control (+/- mute).
Any idea for reason?
Hi @Trixxhelp, welcome to our forum!
That's peculiar!
There are two things we can try to solve this.
You could go back to step 3 and try a different code with the FFWD button or use the manual codes.
The steps to select a code manually, are a bit different. For panasonic you have 7 codes to choose from.
Werkt de snelcode niet of staat jouw merk televisie er niet bij?
Ga dan naar de stappen voor een ander merk TV.
I've copy-pasted the applicable bit from the PDF
Thomas van KPN
That's peculiar!
Thomas van KPN
I havent heard from you so I'm assuming this was the solution!
If you have any other questions you know where to find us!
  • June 6, 2022
Sorry, I did not receive the message about your answer.
I tried both ways but was not succesful. The manual codes did not work.
As I wrote, one code in the step by step worked but was not saved in the remote control.
I assume, the remote is damaged. Thanks for your help anyway.
Thomas van KPN
Ah shame, I think that's very possible!
You can request a new one on this page: Afstandsbediening aanvragen
