TV is stuck on channel 202, nothing helps
  • nov 10, 2023 2:21 p.m. UTC
  • 24 reacties
  • 243 keer bekeken
My TV is stuck on kanaal 202, I can't close it or change it, even if I restart the TV box and the internet. How can I get out of channel 202?
Beste antwoord door TijtheMan
Hi @Sofie1996,
For as far as the systems go, all looks good. I added a test reciever and all channels are available.
However, I do believe there is a channellist (zenderlijst) active. More specific, a channellist without any channels in it (what would explain why you can't see any). So, how to select a different channellist 😊
Go to Menu → Instellingen → Zenderlijsten . If I am correct, you should select 'Alle zenders’ and once selected all channels will be available again.
24 reacties
  • nov 10, 2023 3:06 p.m. UTC
Whish KPN tv decoder do you have?
Wat is channel 202?
  • nov 11, 2023 1:49 p.m. UTC
Joop:
202 Pluspakket on demand aanbod (bron)
Does the red led on the remote work if you try to use de digits? Or P- / P+?
Hello @Sofie1996, is this issue still going on?
  • nov 17, 2023 11:21 a.m. UTC
Yes.
  • nov 17, 2023 11:28 a.m. UTC
Nothing on the remote control works. Not the Bron, not the TV button, nothing but the red and blue buttons that are to subscribe to a new pakket or 'view the pakket '. I can also switch it off. That's all.
  • nov 17, 2023 11:30 a.m. UTC
PeterG, the green led lights up when I push P+ or P-. Not the red.
  • nov 17, 2023 11:40 a.m. UTC
My mistake, but the green is good for the receiver.
Which receiver do you have?
  • nov 17, 2023 11:47 a.m. UTC
I'm not sure I understand the question... The KPN box says ARRIS on it.. Further than that I don't know what kind it is...
And indeed, kanaal 202 is for subscribing for plus pakket, in which I have no interest
  • nov 17, 2023 11:50 a.m. UTC
Which type Arris?
vip2952 with display or the vip5202 without display?
All ready the plug out of mains for about 10 minutes?
  • nov 17, 2023 11:58 a.m. UTC
It's the 5202
I will unplug it now for 10 mins
  • nov 17, 2023 12:17 p.m. UTC
It didn't help
TijtheMan
  • KPN TV
  • nov 17, 2023 12:24 p.m. UTC
Goodafternoon @Sofie1996,
If you haven't done it already, could you please fill in your profile information (accountnumber etc) and then maybe @Jeroen_dB can provide me with the details. So I can take a look in the systems if everything is as it should be for TV to work properly.
  • nov 17, 2023 1:02 p.m. UTC
Hello,
Ok, done. Filled in my details.
  • nov 17, 2023 1:46 p.m. UTC
Please let me know once you could take a look in the system. Also if you need any more info from me. Thank you
TijtheMan
  • KPN TV
  • nov 17, 2023 2:03 p.m. UTC
Hi @Sofie1996,
  • nov 17, 2023 2:15 p.m. UTC
xx
TijtheMan
  • KPN TV
  • nov 17, 2023 2:20 p.m. UTC
Much easier is:
Press the blue button. After a few seconds “zenderlijsten” wil appear.
Select “alle zenders” (and activate with ok)
Return to ‘TV’ with the button on the remote.
😯 This actually is a revelation for me… 😶
  • nov 17, 2023 2:24 p.m. UTC
After testing the trick with BLUE does not work with the channels 200 - 210 😪
  • nov 17, 2023 3:36 p.m. UTC
TijtheMan thank you for the advice, it did the trick!!! It's back to normal finally.
  • nov 17, 2023 3:49 p.m. UTC
Thank you to everyone for the suggestions
TijtheMan
  • KPN TV
  • nov 22, 2023 8:27 a.m. UTC
It does work on channel:
200 - Netflix
201 - YouTube
203 - PrimeVideo
205 - NPO Start
207 - XITE
On the other channels within that range it doesn't work, because the blue button is configured differently (to ‘Open Zenderpakketten’)
  • nov 22, 2023 11:23 a.m. UTC
Ik ben nooit uitgelogd, maar mogelijk omdat ik er dagelijks ben.
  • nov 22, 2023 2:09 p.m. UTC
Ik heb een nieuwe afstandsbedieningbesteld en kan hem niet koppelen aan het kastje alleen aan  de smart tv zelf...ik snap er niks meer van met de oude afstandsbediening dat ik dat ligt daaraan
  • nov 22, 2023 3:29 p.m. UTC
Dit topic is een heel ander onderwerp @Den1e . En betreft een Arris vip5202 ontvanger.
Maak even een eigen vraag (topic) aan om goed geholpen te worden.
Klik hier om een eigen vraag in de rubriek kpn tv te maken.
