A KPN receiver needs a wired connection to the Experiabox.
Hi @Titus V., welcome to our forum!
Did you find a solution yet?
As Henk mentions above, our TV receiver does need a physical cable. There are some shortcuts you can take to prevent having to drill holes in walls or run cables through inconvenient spaces.
Our usual solution is a powerline adapter, we offer these in our online shop as well: Draadloze Verbindingsset 1200 (2 adapters) We also have a dedicated topic with information about these devices:
Keep in mind this solution is a bit more prone connectivity issues than a physical cable.
If you have any other questions you know where to find us!
Hi @Thomas, no not yet. I understand I need a powerline adapter to make the connection, but this wasn't provided with the subscription. Do I have to purchase it separately or will KPN provide this for free? Thank you.
I'm afraid these devices are not included in your subcription.
