Can't order a simcard with a passport that expires within a year
  • mrt. 2, 2024 3:27 p.m. UTC
  • 1 reactie
  • 94 keer bekeken
Hello,
I want to order a SIM only but after entering my residence permit expiry, they said that the expiry date must be at least one year in future. So I can't order the SIM card and I really need connection for my work.
Is it possible to help with this problem?
Thanks!
Hi @Ebrinwa, welcome! Did you try to order online yourself? Or did you try to order via customer service or one of our stores?
If you tried online, I recommend trying again via customer service or a KPN Winkel. Sometimes, the online self-order system is slightly different than ordering through one of my colleagues.
If, however, ordering was already done via customer service or a store, then I'm afraid there's nothing we can do. Perhaps, in that case, you can try and see if you can already get a new residence permit?
In the meantime, you can get a prepaid card. That will at least get you a telephone number that you can use. And if you then, later, do succeed in getting the sim only subscription, the prepaid number can be transferred to it.
1 reactie
  • mrt. 4, 2024 12:20 p.m. UTC
