I can't call abrod after I bought a "Alles-in-1 Zorgeloos" bundle
  • December 10, 2019
  • 54 keer bekeken
Hello,
I just bought a "Alles-in-1 Zorgeloos" bundle and I can’t call abroad. For example, I just try to call in Belgium, and a robot tells me “je kunt niet bellen” and advice me to call at 1244
Should I activate something in order to use my bundle to call abroad?
kind regards,
Lisa
Forum|alt.badge.img+17
  • Oud moderator
  • December 13, 2019
@Octavian Welcome! I can imagine that this is very annoying for you. I don't think I understand you correctly.
  • Do you have an ‘Alles-in-een Standaard’ ,
    • Internet, tv, landline
  • or do you have a  ‘Zorgeloos Standaard’ ,
    • mobile contract, 1 or 2 years
  • or did you buy a prepaid bundle?
    • prepaid simcard
If it concerns a mobile phone, did you enable the roaming function within the settings of your device?
  • December 13, 2019
Hello,
I bought a prepaid bundle (I have a prepaid simcard) and I enabled the roaming function.
Kind regards,
Octavian
Lisa
  • Oud moderator
  • December 13, 2019
Thanks for your fast response. Could you please update your personal profile with your phone number? This allows me to check some settings from our side.
  • December 13, 2019
Thank you for your fast answer. I have done it. Please let me know if you can see it.
Kind regards,
Octavian
Lisa
  • Oud moderator
  • December 13, 2019
@Octavian Thanks! I can see your number. I can't immediately find the cause of this problem. According to my system, you should be able to call to Belgium. You do enter the land number (+32 for Belgium) before you enter the mobile/landline number?
What type of device do you use?
  • December 13, 2019
Hello,
I called using the full number with +32.
My wife faced the same issue and she managed to solve the problem by buying additional credit.
This is how my bundle looks like.
