Is the unlimited plan really unlimited?
  • feb 19, 2023 5:07 p.m. UTC
  • 553 keer bekeken
Jacek K
Nieuwkomer
I am using the unlimited plan, sim-card only. It states that there is no limit to how much internet I use. However, the daily limit is 10 GB, which I can extend by 2 GB as many times as I want.
I want to play some games on GeforeNOW, which is a streaming service (the game runs on a remote server, while my computer only receivs the audio and video, and sends controls input data). It can consume up to 17 GB an hour. Do I really have to extend my bundle by 2 GB for almost 200 times to play a game for 10 hours? It's really time consuming. Can't you add an option to extend the bundle by 10 GB, or 50 GB? Or just get rid of extending it and make really unlimited?
No because that is kinda why it is implemented, so you and your whole family can’t use this as an alternative for a proper router/modem.
  • feb 19, 2023 5:15 p.m. UTC
Jacek K
Nieuwkomer
  • feb 19, 2023 5:33 p.m. UTC
I understand, however I am only using it for my own purposes. I am not sharing the connection with anybody. Therefore, does KPN automatically assume I would be using the unlimited plan to share the connection with everybody in my surroundings?
It’s ok, I understand there are people who would do that. So I am stuck with extending the bundle by 2GB everytime I run out? Or is there another workaround for this?
RBxx
  • feb 19, 2023 6:32 p.m. UTC
KPN isn’t assuming anything. They just supply the connection in this way to discourage you from using it like a fixed connection. You’re stuck with it, there is no workaround.
Don’t you have access to a fixed modem/router connection? That’s really unlimited.
Jacek K
Nieuwkomer
  • feb 19, 2023 7:09 p.m. UTC
Thank you for your response. Yes, I do have access to a fixed connection, but it’s also being used by other household members. Whenever they start downloading something, the quality and stability of my connection drops. Also the other way around, whenever I use streaming services that are extremely heavy on the bandwidth, they start experiencing issues as well.
The best solution here would be to split the total bandwidth in between all users equally, but I do not have access to the router configuration, and it doesn’t belong to me so I shouldn’t modify any settings in the first place.
This is why I decided to use my mobile phone for playing games via streaming services, to separate my network load from the rest of the house.
