Mobile data stopped working
  • sep 26, 2021 10:53 a.m. UTC
  • 13 reacties
  • 1942 keer bekeken
Agaton McManaman
Nieuwkomer
Recently, my mobile data stopped working. I think it may have been after I received a text message from KPN stating that on my request, KPN has updated network settings and I need to restart my device for it to work.
I had not requested KPN to change any network settings, and restarting the device does not help. I have tried everything: turning mobile data/phone/airplane mode on/off, take out and clean SIM card, resetting the phone, etc. When I use another SIM in my phone, mobile data does work, so the problem is with KPN. It has worked previously on this SIM card.
Yesterday, I also renewed my subscription at KPN, and it said it should be activated today. Entering phone+SIM number for activating SIM card does not work, I get an error message stating that due to technical issues they cannot activate it.
Calling works as normal, WiFi works as normal, but mobile data does not work with the KPN SIM. I have an iPhone 8.
Can you help me with this?
Hi @bernaeraslan. Could you please turn your phone off and on again? The option wasn't turned on. It should work now.
13 reacties
Lisa
Forum|alt.badge.img+17
  • Oud moderator
  • sep 26, 2021 11:21 a.m. UTC
Hi @Agaton McManaman! Welcome here. I'm sorry that your sim-card stopped working. Do I understand correctly that you already received a new SIM-card, since you needed to activate SIM card, or not?
I would like to check what is going on. Can you please enter your subscription details in your profile and let us know when you did so? Postal code, house number, customer number and the last 3 digits of the bank account number known to us is sufficient.
  • sep 26, 2021 11:27 a.m. UTC
My subscription details are in this profile
Edit: I am not finding a box to enter anything abot bank account number.
To clarify: I did not receive a new SIM card, I am still using the same old one. I just extended the subscription on the same number. Calling works without problems on this old SIM card. I just checked if I could activate it again to see if this would solve the problem.
Forum|alt.badge.img+28
  • sep 26, 2021 12:34 p.m. UTC
  • sep 26, 2021 6:09 p.m. UTC
It is working now. It was not working for four days. What was the reason for this? I have complaints
  • sep 26, 2021 6:17 p.m. UTC
Not really sure, I just did a quick reset of the connection and could see that everything was back online. I'm sorry for the inconvenience.
  • jul 6, 2022 9:39 p.m. UTC
Please how do I restart my phone after I turn it completely off. There are four number digit I need to use but I don't know it?
  • jul 6, 2022 10:32 p.m. UTC
Hello @Daniel zz
Is it asking for the sim pincode?
You should have received documentation with the simcard on which it is mentioned, but if you changed the pincode that is not correct anymore.
If you don't have that anymore you could try 0000 or 1234
After three times entering the wrong pincode it will ask for the pukcode, you should also have received that with the simcard.
You also can get it through this website after filling in the details: https://www.kpn.com/service/mobiel/pukcode.htm
Probably you need the second option: https://www.kpn.com/service/mobiel/pukcode/pukcode-opvragen.htm
If it's greyed out and hard to read on the website click on it to make it visible.
After entering the pukcode you have to fill in a new pincode on your mobile.
  • jul 18, 2022 9:14 p.m. UTC
I have cellular error and my phone completely stopped working? Could someone pls urgently help?
  • jul 19, 2022 3:07 p.m. UTC
What do you see exactly on your screen? Which error?
Ezgi Erdogan
Nieuwkomer
  • mei 5, 2023 10:12 a.m. UTC
Hi! I have the same problem. I arrived France just an hour ago and my internet is not working. I am stuck in train station to use the wifi here. I tried calling kpn and called 2 numbers but I couldn't reach one and the other was not English and my Dutch is not good. I need immediate help.
I got this message and translated it that I can use my internet but WHY can't I?
  • mei 6, 2023 6:35 p.m. UTC
Hi @Ezgi Erdogan, welcome on our forum. First off please check if Roaming is ON. After that you should try selecting other available networks, you can do this manually in the settings of your phone.
Ezgi Erdogan
Nieuwkomer
  • mei 6, 2023 7:14 p.m. UTC
Hi! After half a day, and with the help of a Dutch lady, she helped me to be called back and the person there was very helpful. Thank you.
P.s. Please add English to your callcenter at least. I'm sure you have many subscribers who don't know Dutch yet^^
Thank you
  • mei 6, 2023 8:04 p.m. UTC
I'm glad it works now. Thank you for the suggestion regarding the English option, I will pass it on.
