New sim locked and PUK code not working
  • jul. 27, 2023 2:14 p.m. UTC
  • 139 keer bekeken
Hallo, I received my KPN sim card recently, with number transfer from different provide.
Today is the 1st day of my contract. I have put the sim into my iPhone and it says SIM locked.
I tried to fill in the PUK code. 3 times…
(I used PUK code from the letter) and I also checked PUK code here on the web site (it is the same).
I have 2 attempts left.
I am confused, what should I do ?
Beste antwoord door RBxx
Did you not use the SIM PIN code? The standard PIN code of a KPN SIM card is 0000 (4 zeros)
2 reacties
RBxx
  • jul. 27, 2023 2:21 p.m. UTC
RBxx
  • jul. 27, 2023 5:10 p.m. UTC
Hi @K.Kuzmenko
I see you marked my answer as “Best Answer” and I hope that means your problem is solved.
