New subscription activating while abroad
  • jul. 17, 2023 8:14 a.m. UTC
  • 126 keer bekeken
Hi,
I transitioned my mobile contracts including two phone numbers to KPN. I have already recieved the SIM cards, and am now waiting for the transition to finalize. I unfortunately didn’t think about being abroad in Germany for holidays, and now the actual activation of the contract with KPN will happen while I am there.
I read here that this may be a problem. I think my situation is somewhat different as I already have the SIM cards. Does it help to “activate” them already (put them in a phone and unlock?), even if they won’t actually work. Are there any other ideas how to make sure that I don’t lose mobile connectivity completely?
Thank you!
Hi @usch, welcome on our forum.
This is quite a difficult situation, for privacy reasons.
When will you be back from Germany? Is your current provider still working (current SIM cards)? Did you receive a confirmation, from KPN, regarding the transition of your numbers? If so, is there a date mentioned?
Perhaps much easier, could you please reach/call us? Our number from abroad is +31 6 1200 1200.
Forum|alt.badge.img+28
  • jul. 22, 2023 11:24 a.m. UTC
RBxx
  • jul. 22, 2023 1:09 p.m. UTC
Perhaps much easier, could you please reach/call us? Our number from abroad is +31 6 120 1200.
One digit is missing there.The correct number is +31 6 1200 1200
  • jul. 22, 2023 1:39 p.m. UTC
Thanks Ruud!
  • aug. 8, 2023 6:13 p.m. UTC
Hello,
just quickly reporting back. I called the hotline and the agent thinks it will work fine as long as I am within Europe. The switch happens in a few days, fingers crossed that it goes smoothly.
Thanks!
  • aug. 9, 2023 1:30 p.m. UTC
Yes, this will happen after 21 days after ordering and receiving the sim card. Till then you should be able to use the sim card form your "old” provider.
