Nummer van de klantenservice werkt niet
  • aug. 20, 2024 2:09 p.m. UTC
  • 131 keer bekeken
Hello,
I’m trying to call to customer service by 0800-0402 or 1200, and after it says that the call is being recorded for better service (on Dutch of course), then the call is ended.
How can I reach an operator to talk (about new subscription plan ) ?
Hi @Mar_ina! If you’re in The Netherlands, 0800-0402 should work. If you’re abroad, we’re available through +316 1200 1200. Could you check to see if that works?
You can reach us between 8:00 - 18:00 on business days and between 8:00 - 17:00 on Saturdays. Hopefully you'll be able to get in touch with us this way!
Sanne van KPN
  • aug. 21, 2024 2:48 p.m. UTC
  • aug. 22, 2024 10:38 a.m. UTC
Ah yes, issue was with my phone. All calls ended in 10 sec 😅
restart, and now I can call.
Thanks.
Sanne van KPN
  • aug. 22, 2024 1:06 p.m. UTC
Haha, good! Glad you found the solution. You’re welcome!
