OnePlus 7 (pro) en 4G bellen / VoLTE
  • October 13, 2020
  • 46 reacties
  • 2223 keer bekeken
46 reacties
  • May 8, 2021
Ik denk dat je meerdere mensen zou kunnen helpen door dat EU/KPN modem profiel met anderen te delen.
@bartz
Mag ik dit profiel delen hier?
  • May 8, 2021
Ik zou niet weten waarom niet.
Ik zal het zo delen met de software die je nodig hebt en een stappenplan. Geef me 20 minuten aub
download eerst de benodigde files op de pc. ik heb het goede profiel (kpn) al in de efstools folder gezet. folders wel nog even unzippen en eerst de quadwin installeren(driver modem telefoon):
de link:
https://we.tl/t-CQhooNk6lg
volg nu onderstaande stappen:
Step 1 - Install oneplus Logkit and engineeringmode working apks.
Oneplus Logkit - https://drive.google.com/file/d/13YugwyZ-dMH2474h-DjLVzPNsrs7EJ0k/view?usp=sharing
Oneplus Engineeringmode - https://drive.google.com/file/d/13QPmtbVL4hCJbXYOVHtq36GzRhtKSlOe/view?usp=sharing
Step 2 - Enable VoLTE and VoWIFI
In Phone app dial *#800# - this will open the OnePlusLogKit app
In OnePlusLogKit app go to Function Switch menu and enable VoLTE switch, VoWifi switch and VT switch
Step 4 - enable engineer mode and test connection
In Phone app dial *#801# this will open EngineerMode
In EngineerMode app enable engineer Mode toggle and connect phone to PC
test connection - run this in the cmd window: EfsTools.exe efsInfo
This should report back some info if everything is working
Step 5 - disabling mcfg
Extract EfsTools, and make sure the mcfg_autoselect_by_uim file is there. Now simply run this in the cmd window, one line at a time:
EfsTools.exe writeFile -i mcfg_autoselect_by_uim -o /nv/item_files/mcfg/mcfg_autoselect_by_uim
EfsTools.exe writeFile -i mcfg_autoselect_by_uim -o /nv/item_files/mcfg/mcfg_autoselect_by_uim -s 1
If everything worked you should see no error messages.
Step 6 - writing mbn
First you need to find an working MBN file for your carrier, this is done by going in firmware_mnt and looking for the mbn files with and root explorer
For my carrier i'm using the india vodafone mbn file wich is already present in the efstools zip i provided, if this is not working for you upload the firmware_mnt folder and i will upload and update this guide with all the mbn files. I am not rooted and can't do that.
Also the india vodafone mbn file is from OOS11 oneplus 7T 11.0.0.0 and it works on 11.0.0.2 also.
For sim 1 use this command: EfsTools.exe uploadDirectory -i mcfg_sw.mbn -o / -v
For sim 2 use this command: EfsTools.exe uploadDirectory -i mcfg_sw.mbn -o / -s 1
If it has worked you should see a bunch of output, but no errors. Try rebooting now, and hopefully after it has booted you will have fully functional VoLTE and VoWiFi.
Chris Kruijntjens.
Kleine update op bovenstaande,
Als je een os update krijgt van oneplus moet je bovenstaande herhalen, want het modem profiel wordt dan gereset.
De fout in deze ligt niet bij kon maar bij oneplus. Die hebben gewoon niet het nieuwe profiel toegevoegd in de image van de oneplus 7t. Ik heb deze nu dus uit de image van de 8t gehaald.
Is het gelukt @wjb ?
  • May 24, 2021
Reagerend op bovenstaand stappenplan; welk profiel gebruiken jullie nu om VoWiFi werkend te krijgen bij KPN?
  • August 8, 2021
de link:
Chris Kruijntjens.
Beste Chris, kun je de modem files alsnog delen?
  • August 8, 2021
Dank Chris maar inmiddels niet meer nodig. Was zo klaar met KPN waarmee het mij maar niet lukte terwijl het bij andere providers welk mogelijk wordt gemaakt met hetzelfde toestel. Ik gebruik nu  WiFi bellen via Hollandsnieuwe met Vodafone netwerk en dat werkt perfect op de Oneplus 6.
@ckruijntjens.
Zou je het profiel kunnen delen aangezien de download link is verlopen? Wil het ook eens proberen. Alvast bedankt.
  • September 18, 2021
Inmiddels zonder zelf dingen te moeten doen werkt het nu na laatste update op mijn oneplus 7 pro!
  • September 20, 2021
Wanneer heb je deze update ontvangen?
Vorige week, via de oxigen updater app.
Het is gelukt hartelijk dank hoop dat er meer mensen blij van worden
  • September 21, 2021
Goed te horen dat VOLTE nu werkt met Oneplus 7. Weet iemand of dit ook nu werkt op de Oneplus 7T?
Pylsa
Topper
  • September 30, 2021
Bij mij inderdaad ook binnen, en eindelijk VoLTE! Hier word ik blij van!
Pylsa
Topper
Kleine toevoeging! Voice over WiFi werkt bij mij nu ook! Prachtig
Welke software heb je nu geïnstalleerd en welk toestel gebruik je als ik vragen mag?
Pylsa
Topper
Ik heb een OnePlus 7 Pro (geen T) en heb gewoon de laatste systeemupdate geïnstalleerd die werd aangeboden. Daarna werkte alles meteen.
