Order was cancelled because I could not pin at door. Now what?
  • October 11, 2021
  • 148 keer bekeken
Slkeyo
Nieuwkomer
I ordered a phone with a KPN subscription last month, and it was delivered today. The thing is, I was asked to enter bank pin code which I forgot, and therefore the delivery guy could not give the phone to to me and told me to make a new appointment.
And just now I received an email said my order is going to be cancelled because it was refused by the door. What am I going to do, make a new appointment or wait for my refund? It has been more than 14 days after I purchased it, so is it possible to get my refund? How long will it take ?
Beste antwoord door Hanna_
Hi @Slkeyo, welcome.
If you recieves a confirmation email in which it clearly states your order is cancelled, you should recieve a refund within 5 buisness days. If you want you can place another order for the same phone/subscription. Make sure you enter the correct information. You may also go to a KPN store and take place your order there. Often times, you'll be able take the smartphone with you right away.
2 reacties
Slkeyo
Nieuwkomer
  • October 11, 2021
I contacted customer service today, he said I would recived a link for changing appointment time, but I didn’t rececive it
Hanna_
  • October 12, 2021
If you recieves a confirmation email in which it clearly states your order is cancelled, you should recieve a refund within 5 buisness days. If you want you can place another order for the same phone/subscription. Make sure you enter the correct information. You may also go to a KPN store and take place your order there. Often times, you'll be able take the smartphone with you right away.Â
