Preordered a Galaxy 5 with physical sim, but order says Galaxy Flip 5 e-sim. What to do?
  • aug. 10, 2023 7:42 p.m. UTC
  • 70 keer bekeken
Hy guys i just order glaxy 5 from kpn store but the problem is i asked her for the plastic sim and i just came back home and its says glaxy flip 5 256gb esim and i told the lady there to put the plastic simĀ  what can i do now i can modify the order or what and i cant go back to store for 2 3 days because am busy .
Hi @Kpn store preoder problem,welcome to our forum!
It seems a mistake was made somewhere as that's obviously not what you ordered! Is it a new subscription or a renewal?
If it's a renewal it doesn't really matter as you can still keep using your old simcard.
If it's a new subscription you might want to request a physical card when the subscription starts. You can do that by phone on 0800-0402 or in a physical shop
2 reacties
RBxx
  • aug. 10, 2023 9:11 p.m. UTC
The Samsung Galaxy Z Flip5 is a Dual Sim device:Ā Ā NanoSIM + eSIM
Thomas van KPN
  • aug. 15, 2023 10:22 a.m. UTC
