What is my 5G Datalimit?
  • October 6, 2021
  • 62 keer bekeken
What does mean 5 G data limit , and What is my data limit ?
  • October 6, 2021
What is my data limit?
Nico_
Topper
  • October 7, 2021
Goodday @Sharif massoud and welcome!
Your data limit depends on the kind of contract you have with us. If you could fill in your forum profile with your personal information (only we moderators are able to see that information and you) so i can check it for you.
Can you give me a reply here when you're ready?
Nico_
Topper
  • November 4, 2021
Hi @Sharif massoud. I have not recieved another message from you. Have you found your answers?
  • November 5, 2021
4G en 5G are networks.
A data limit is in GB.
This is 1000 MB. With a limit of 5 GB per month you can use 5000 MB.
Example: a HD videostream uses 0,625 MB per second.
When you are at home, on your wifi, you don't use de mobile data. So you don't eat up your limit then.
A text message with Whatsapp (text only) is about 2 Kb.
Sending a picture about 2 MB.
Voicecall about 705 MB per minute.
Videocall about 5 to 20 MB per minute
(source of information)
