Where can I find the PUK code?
  • August 17, 2022
  • 256 keer bekeken
where can I find the puk code?
Beste antwoord door RBxx
Hi @RachelVelvet there are several options.
The puk code is mentioned on the plastic card in which you received the sim card. You’ll find the puk code in MijnKPN and if that doesn’t work you can use this online form as well.
2 reacties
Hi @RachelVelvet, welcome to our forum!
The fastest and easiest way to look up your pukcode, is via MijnKPN. The page I linked to will show you the way. Please let me know if it worked out.
RBxx
  • August 17, 2022
