Can someone explain the pattern of the wifi blinking light
  • September 5, 2022
  • 757 keer bekeken
threeof4
Nieuwkomer
Can somebody explain the flashing light sending a code? My wifi light is not on-off-on-off  but more like this:
On (for couple of seconds) off/  on/off/ on/off/ on/off/ on/off/  on(for couple of seconds) signaling #4.
I noted this and this 'signal’can go from 2 up to 20 flashes. So a patern might look like this:
2 (flashes), 2, 4,4,4,4,18,16,4,2,4,6,20 etc.
During these flashes I notice my ICS-2000 (klikaanklikuit internet control station) flashes red once every couple of minutes, showing it has lost internet connection temporarily.  The wifi turned bad a couple of weeks ago after a update but this signalling is there since I got this model modem.
Admin: eigen topic aangemaakt
Hi @threeof4, as far as I know, there is no secret message or anything in the pattern. It's just a blinking light! If the wifi isn't working as it should, you might want to use our Wifi Manager.
  • September 6, 2022
Hello @threeof4
It depends on the modem type what the light does.
For example on a Box 12 it's sending data when it blinks.
threeof4
Nieuwkomer
  • September 6, 2022
Mmm i don’t think its that. It is very steady pace the light blinks. Like almost a second for pauze and almost a second ‘on’. For data i would think it would be more like ethernet light on the back of the modem.
Marcia van KPN
  • September 10, 2022
