How to login to my Box 12 modem?
  • January 17, 2023
  • 235 keer bekeken
Greetings. I hope you are all well.
I had to replace and modem and now need to add a 2.4 network for basic needs such as the doorbell, etc. Unfortunately, the admin portal seems to be down for an extended period of time (http://mijnmodem.kpn/2.0/gui/#/login/). I called yesterday and was told that there is a known issue. It was suggested that it may take a day . . . or two . . . or three, and that I should check back. It’s still down and vulnerable of missing package deliveries.
If this is the platform that we use to add basic functions like a 2.4 network, can this outage be escalated for accelerated resolution? We shouldn’t have to be inconvenienced for a few day to restore an important basic service. Is there another way to add the 2.4 network?
Thanks for your consideration and support.
7 reacties
Bram van KPN
Forum|alt.badge.img+17
  • January 22, 2023
Hi @Scot! Welcome to the forum. In this case “Extra Wifi” would be an ideal solution for you (translated with Google translate here). It is a function that creates a seperate dedicated 2,4GHz or 5,0GHz network.
For this, you will need to log into your modem. About that, there are a few things you can do.
  • delete your browser cache
  • try a different browser
  • make sure you don't have a VPN active
  • make sure you are using the right Admin Password.
Let me know here if those options work for you? And if Extra Wifi fixed the issue?
  • January 22, 2023
Hi Bram,
Thanks for your consideration. Apparently, there is a known bug in the V12. It might be helpful if internal communications were distributed across KPN since different support agents seem to lack this awareness.
I appreciate all the help and look forward to hearing that it has been resolved (how that may happen is unclear).
Wishing you all the very best,
Scot
Hi Scot, I had the same problem yesterday, for me the only thing that worked was connecting my laptop to the modem with a cable
  • January 22, 2023
Interesting! Thank you for the feedback! I am thankful you were able to get it resolved. I will check it out…..
  • January 22, 2023
Mm. I don’t see how to connect the laptop directly to the modem. My laptop only has USB and Type C, I think. I played around, but nothing worked. I appreciate your feedback, Gelderlander81. 🙏
Mine also only has a usb c connection, but I bought a convertor
  • January 22, 2023
Great! Thanks so much again for your support, Gelderlander81 and Bram_
Wishing you all the best in life.
