It is not possible to turn off Wifi radio with the KPN Experiabox V10
  • April 4, 2024
  • 178 keer bekeken
Hello.
I have a problem regarding xperia v10 router. I can’t turn off the wifi radio. The button shows that is off but in reality the radio is on. What am I missing here? I read somewhere on this website that keeping the WPS button pressed for 15 secs will turn off radio but that’s not the case! WHY this cannot be turned off?
I even tried the schedule - again the radio is still on.
Hi @Florin1up, welcome to our forum! There's multiple ways you could turn off the Wifi on your V10.
You can read all about this in our knowledge base:
If it does not work you could try giving your V10 a factory reset
Cappuccino2
Helper
  • April 5, 2024
You could try login in the modem and disable wifi there.
  • April 5, 2024
Thanks for info, I did, the button in the interface shows that wifi is off but in reality it’s not.  Also on the status webpage of the modem shows “radio enabled”. Looks like there is absolutely no way to turn off radio on this
Thomas van KPN
