Looking for a private modem/router to replace my KPN Box V12
  • January 29, 2024
  • 8 reacties
  • 371 keer bekeken
Hello,
I Have fiber optic connection and KPN Box V12 serving as a modem, which is connected by ethernet to TP-Link Deco X50 3-Pack mesh, which I use as wifi. I turn of the wifi coming from the KPN Box V12.
the deco serves as acsses point only mode,
however i’m not happy with internet currently, and face many lags and issues with it.
that’s why I want to use a private better modem. is this possible ?
this is what I get from kpn service tool -
Your connection type
GoF
The modem you received from KPN
KPN Box V12 F5359
Your current fiber optic connection point (FTU)
FTU_TY01
Own or a KPN fiber optic ONT
KPN ONT
Your own modem must meet at least the following requirements:
  • Ethernet connection with WAN port with RJ-45 connector for use of UTP (twisted-pair) cables.
  • Please note: use the available NTU media converter (with Ethernet connection and RJ-45 connector). The fiber optic in the FTU (where the glass is mounted) is very vulnerable. Disconnecting it from the NT (with Ethernet connection) is strongly not recommended.
8 reacties
  • January 29, 2024
If you don't have a televisie subscription at KPN you can use many routers as long as they are able to setup a pppoe connection vlan 6.
  • January 29, 2024
@sar12 You can use the Deco Main Node as Router connecting to KPN ONT.
You can use anything for username and password
Internet VLAN 6/Priority 1
IPTV VLAN 4/Priority 7
By example Port 1 - WAN : VLAN 6
Port 2 - IPTV: VLAN 4
Port 3 - Ethernet Backhaul to 2nd Deco Node
  • January 29, 2024
Thanks, I don't have IPTV. Just kpn internet only
  • January 29, 2024
@sar12 If you don't have IPTV, you don't need to enable IPTV/VLAN, just Internet VLAN
  • January 29, 2024
Thanks for the help 🙏🙏
  • January 29, 2024
This does not work with TV from KPN as this is so-called bridged-IPTV where KPN uses routed-IPTV where the settopboxes are on the same (V)LAN as all other devices and an IGMP proxy server need to be configured to get the TV streams from vlan 4 at the WAN side.
But fortunately @sar12 does not have television from KPN.
  • January 30, 2024
@wjb Deco x50 supports IGMP Proxy
https://www.tp-link.com/nl/home-networking/deco/deco-x50/#specifications
IPTV IGMP-proxy
IGMP-snooping
Bridge
Tag VLAN
  • January 30, 2024
IPTV IGMP-proxy
IGMP-snooping
Bridge
Tag VLAN
Correct but the configuration you showed seems to be for bridged-IPTV and not for routed-IPTV.
With routed-IPTV the settop boxes should not be configured on a separate vlan.
But for TS this does't matter as he has no TV subscription.
