Modem admin password keeps changing
  • December 3, 2022
  • 261 keer bekeken
I am trying to access the admin panel settings but I keep being locked out. After resetting, there is a brief period where I can use the default admin password at the back of my KPN Box 12. after changing the password to one that I choose, it works fine. BUT as soon as there is internet connectivity, the admin password changes and I am locked out. I assume this is done by KPN. I would like access to the admin panel please, as I want to change the wifi name, password etc.
Beste antwoord door Anonymous
Hello @0xffff
To login in the Box 12 this link probably will work: https://192.168.2.254/2.0/gui/#/login/
Forum|alt.badge.img+2
  • December 3, 2022
Hi i think it is possible to reset the modem using your online account at kpn.com. I guess there is  an online copy off your config. Reset  using your account should also remove this config.
  • December 3, 2022
Hello @0xffff
  • December 3, 2022
Hi @0xffff Nice username! config register?  😀
  • December 3, 2022
Hello @0xffff
A note for anyone else who runs into this issue. It’s confusing. As @GeSp points out, you should access it via the IP address, not the dns name “http://mijnmodem.kpn/2.0/gui/#/login/”. For some reason accessing it via the dns name will cause your password to fail. Accessing via the ip address seems to work fine. What’s weird is that mijnmodem.kpn points to 192.168.2.254, as expected.
  • December 3, 2022
Nice it's working for you, it's indeed a very weird bug in the Box 12 modem interface.
