Port forwarding doesn’t open ports
  • January 11, 2025
  • 109 keer bekeken
I have a KPN Box 12 and set up a reserved IP on my PC to keep it from changing.
In the router's port forwarding settings at mijnmodem.kpn, I opened a port for this reserved IP.
However, I couldn't connect to it at all.
I tried a telnet test to see if something was wrong and I got an error saying it couldn't connect. Also, when I run a netstat, I can see that nothing is listening on the port I opened. Has anyone else had this issue? It looks like the port forwarding in the router settings doesn't do anything.
HeidiV
Topper
  • January 11, 2025
Hi ​@Sashi
If netstat shows nothing listening then that's the problem, not the portforwarding.
The service which listens on that port should be running first.
Did you manage to resolve the issue yet? Did you try using an alternative port for the application?
  • January 15, 2025
No, I wasn't able to resolve it. I tried using multiple different ports through the port forwarding interface but couldn't connect to any of them.
HeidiV
Topper
  • January 15, 2025
If there is no service running on the device you forward the port to then it shows the port closed from the internet.
Is there a service running on the port you forward to and is it reachable from the internal netwerk?
