Problem with reseting modem to factory setings
  • December 20, 2022
  • 91 keer bekeken
hi, sorry for writing in english, last week i reset the modem to factory settings by presing the buton behind the modem and it worked fine, but for some reason i forgot the pasword so i wanted to reset it again to factory settings and now it doesnt work anymore, i have tryed with the small buton and with the app and both dont work.
Beste antwoord door Anonymous
Hello @benjib ,
Wich modem type have you?
Can you try the reset with this link: kpn.com/reset
How mani seconds have you putt on the reset button?Can you, if the link not works, try to putt on the reset button for 15 seconds?
I hope that it works!
2 reacties
  • December 20, 2022
Hello @benjib ,
  • December 24, 2022
Hi Martijn,
I figured out that the modem was not the issue, i could eventually log in by using edge browser instead of google chrome... that was the fix. For some reason with google chrome it didnt work anymore.
Â
