Setting up a 2.4 GHz network with Experia Box V10
  • okt 21, 2025 8:36 p.m. UTC
  • 114 keer bekeken
Hello, apologies for this post in English. I am trying to set up an extra 2.4GHz WiFi network in my home on the Experia V10 Box (Firmware Version:v5.00.61 build511).  I have followed the instructions in the knowledge base. However the box does not save the settings and so the network is not set up. I toggle the switch to select the extra wifi network (see picture),  however when i press save, the switch toggles back to the off position and so i cannot set up a 2.4GHz network? thanks in advance for your help.
Hi ​@HECLYR and welcome to our KPN Community! Good question and odd that your router isn't saving the settings.
Resetting your Experia Box V10 would be my first advise here too. Hopefully it will save the settings after that.
Regardless of getting the update or not, it should save the settings so hopefully this helps!
Leen59
  • okt 21, 2025 9:03 p.m. UTC
Hi, your V10 is still running on old software. Try a factory reset for an update.
Sanne van KPN
  • okt 23, 2025 5:13 p.m. UTC
  • okt 25, 2025 8:17 a.m. UTC
Thank you, that has worked.
  • okt 25, 2025 9:30 a.m. UTC
Hello ​@Sanne van KPN en  ​@Leen59 , ​@HECLYR has a V10a and not a V10, that is a big difference
