How do I cancel my prepaid mobile sim subscriptions?
  • apr 18, 2019 10:27 a.m. UTC
  • 1084 keer bekeken
sOh
*Admin: titel van je bericht aangevuld ter verduidelijking
Beste antwoord door Andy21
I got to chat on the app and managed to cancel both pre paid sims.
all good now.
  • apr 19, 2019 10:28 a.m. UTC
Just use the "beltegoed" (calling credit) until it's finished. Otherwise it's a waste.
To finish the prepaid just don't use it anymore. Six months after last use it wil be blocked, than you can no longer call yourself. Then 3 months later is it definitely stopped. So, nine (9) months after last use it definitely ends.
Bart_
  • apr 19, 2019 11:06 a.m. UTC
Hi @Andy21 Did you see Peters reply? Does it answer your question or is there anythinh I can help you with?
  • apr 19, 2019 12:06 p.m. UTC
all good now.
