Sim card activation doesn't work in Germany
  • May 24, 2023
  • 160 keer bekeken
Dear Support Team,
I purchased the prepaid SIM and the guy in store he told me i can activate in from any where in EU but now i am not able to activate, even sending messages failing and also calls not going through so can you activate it? My number is **********
Thanks,
Anand
Admin: removed phone number due to privacy concerns. Please don't post any private information publicly
Beste antwoord door Anand15
Hi @PeterG and @Bram_
Thanks you very much for your timely help and my Sim is activated now :-)
Have a nice day!!
Regards,
Anand
7 reacties
  • May 24, 2023
Prepaid simcard can only be activated in the netherlands via KPN Netwerk.
End then it can be used in all countries of European Economic Region + Switserland.
I inform moderator to activate your card.
RBxx
  • May 24, 2023
Hi @Anand15
Place your 06-number and the simcard number in your forum profile. Both are needed.
Use the field “Persoonlijke opmerkingen” and save your input by pressing “Sla wijzigingen op” at the bottom of the page.
Report back here when you’ve done that.
  • May 24, 2023
Hi @PeterG  and @RBxx
I have saved my mobile number and Sim number into personal comments so please could you read it and activate it now?
Thanks again for your help.
Regards,
Anand
  • May 24, 2023
Hopefully @Bram_ can activate it now.
@Anand15 . Can you try if it is already activated?
  • May 24, 2023
Hi @PeterG
Still not activated.  Neither calls nor messages going through :(
Thanks,
Anand
  • May 25, 2023
Have a nice day!!
Regards,
Anand
  • May 25, 2023
For Beltegoed use only http://kpn.com/prepaid/opwaarderen.htm @Anand15 . From outside Netherlands.
Validity prepaid.
Use at least within 6 months with placing a call with connection. Send sms. And/or buy '’beltegoed'’.
After first activation place at least € 10 beltegoed within 7 days.
