Sim card activation not working
  • apr 8, 2021 1:04 p.m. UTC
  • 378 keer bekeken
Hello there, I bought I sim card yesterday and it got delivered very fast. I received it today. I am in the Netherlands.
No matter what I do I am not able to use the phone. I received a code to activate via App but I still am not able to make a call. Also it says I have 2,50 Euro on it.  Also I restarted my phone. What am I missing?
Beste antwoord door Bart_
Hey @Tabea S. Thanks for the screenshot; that explains a lot. You do have some bonus credit, but your out of regular calling credit. You will need to upgrade your regular calling credit, to able to you use the connection and to use the bonus credit.
7 reacties
  • apr 8, 2021 12:31 p.m. UTC
No matter what I do I am not able to use the phone. I received a code to activate via App but I still am not able to make a call. Also it says I have 2,50 Euro on it. What am I missing?
*Admin: merged with existing topic
  • apr 8, 2021 12:32 p.m. UTC
ah, and also I restarted my phone
Bart_
  • apr 8, 2021 2:31 p.m. UTC
Hi @Tabea S. That's weird. You followed the correct steps, as it seems to me.
Just a guess: you come from abroad, as does your phone? It could be that your phone is not able to connect to our bandwith / network. Could you try using another phone, just to test this?
If that doens't help, let us know: we'll have a closer look then. In that case, could you filll in your mobile number and the number of the kpn sim card in your forum profiel?
  • apr 8, 2021 3:11 p.m. UTC
I uses this phone before with Lebara. Also I used the App and it says everthing is fine, I have 2,50 Euro which is coming with the purchase. Then I make a call and I get the message I cannot make a call and this costs me mone. Now my balance is around 2,30 Euro. I hate this
  • apr 8, 2021 3:18 p.m. UTC
Denise van KPN
Strange, I don't see any reason why it shouldn't work. What kind of phone do you currently use?
Bart_
  • apr 9, 2021 6:23 a.m. UTC
