KPN Box 12 internet drops intermittently
  • July 5, 2022
  • 12 reacties
  • 264 keer bekeken
Good evening,
I’ve been customer since yesterday. Internet dropped several times in day with WiFi. I am working from home and I felt the outages with the freezing Zoom sessions.
I tried resetting modem, and checked cabling. You can find the modem logs, these times matches with the issue times I observed.
05.07.2022 17:13:04 Warning PPPOE
Connection to the Internet has been terminated.(Reboot,Reconfiguration,forced termination)
05.07.2022 17:13:04 Warning DHCPC
WAN DHCP client (1) stopped
05.07.2022 15:47:35 Warning PPPOE
05.07.2022 15:47:34 Warning DHCPC
05.07.2022 13:41:53 Warning DHCPC
05.07.2022 13:40:15 Warning PPPOE
05.07.2022 13:40:15 Warning DHCPC
@nrls I've been able to make a service ticket. This ticket will be picked up tomorrow. We will call you on the number you have provided.
I've made a comment in the ticket that you speak English only. I can not guarantee the person calling you will speak perfect English however. So if possible please see if you can have someone near who will be able to translate.
Because I`m sure this action will resolve the issue I`m closing the topic. If you have any other questions however you can always ask them here.
12 reacties
Bram van KPN
Forum|alt.badge.img+17
  • July 7, 2022
Welcome to our forum @nrls! Is it just the wifi dropping or does the wired connection drop too?
Also, could you check to see which firmware version is installed on your Box 12? You can find more information on how to check in our Box 12 firmware topic
Lastly, you've mentioned using Zoom. Does it matter how many devices you use when the connection drops?
Please let me know here and we`ll see how we can fix this.
  • July 7, 2022
Hi Bram, the modem is in my meterboard and I am connected to it from a single Macbook with wifi, thus I don’t know about the wired connection. But when the problem occurs, wifi connections still keeps alive but only the internet connection not works.
I have firmware SGEJ10000528, I think it is the latest version.
Finally, as I said I am only one in the house and connecting with single computer, so I couldn’t observed it with multiple devices.
Thanks!
Bram van KPN
  • July 8, 2022
@nrls I think it's wise to see if we can get an engineer to go to your house. However yesterday I saw no problems with the connection.
What I would recommend is to wait for the next day where you have 3 or more disconnects. If this is the case please call 0800-0402. They should be able to send an engineer on the basis of the dropping connections. If not please let me know here on the same day so I can further assist you.
  • July 13, 2022
Hi  @Bram_ , I had 3 disconnect problems in last 24 hours. I tried to call 0800-0402 but it is only working in Dutch I guess (which I cannot speak), so is it possible for you to arrange an engineer to come to my house? Or is there any other channels that I can do it myself?
Thanks!
Bram van KPN
  • July 13, 2022
  • July 6, 2023
deleted
  • July 6, 2023
Hello,
I am having an intermittent internet dropping issue recently. I had a similar one before, and has recently gotten intense again.
You can find the logs of my modem for the last few days below:
06.07.2023 17:32:02 Warning PPPOE
06.07.2023 17:32:01 Warning DHCPC
06.07.2023 14:11:15 Warning PPPOE
06.07.2023 14:11:15 Warning DHCPC
06.07.2023 11:03:18 Warning PPPOE
06.07.2023 11:03:18 Warning DHCPC
06.07.2023 11:01:02 Error WIFI
A device failed to connect to SSID (16:8F:6E:BC:8E:DB) because it provided incorrect login information.
06.07.2023 10:03:09 Warning DHCPC
06.07.2023 10:01:18 Warning PPPOE
06.07.2023 10:01:18 Warning DHCPC
05.07.2023 08:06:26 Error WIFI
A device failed to connect to SSID (6E:62:81:87:5C:A6) because it provided incorrect login information.
05.07.2023 01:19:00 Warning PPPOE
05.07.2023 01:18:59 Warning DHCPC
04.07.2023 15:25:43 Warning PPPOE
04.07.2023 15:25:43 Warning DHCPC
04.07.2023 10:05:16 Warning PPPOE
04.07.2023 10:05:16 Warning DHCPC
03.07.2023 21:40:04 Error WIFI
A device failed to connect to SSID (88:D8:2E:07:89:0B) because it provided incorrect login information.
A device failed to connect to SSID (B0:4A:39:0A:34:F0) because it provided incorrect login information.
03.07.2023 21:40:03 Error WIFI
03.07.2023 19:49:36 Error WIFI
A device failed to connect to SSID (DC:E5:5B:43:5B:49) because it provided incorrect login information.
03.07.2023 19:49:34 Error WIFI
A device failed to connect to SSID (B0:BE:83:24:08:E5) because it provided incorrect login information.
A device failed to connect to SSID (B0:DE:28:05:ED:26) because it provided incorrect login information.
01.01.2020 01:24:04 Error WIFI
03.07.2023 17:48:53 Warning PPPOE
03.07.2023 17:48:53 Warning DHCPC
03.07.2023 13:46:44 Error PPPOE
PPPoE error: timeout
Admin: condensed error messages and merged topics
  • July 7, 2023
And still going on today:
07.07.2023 10:45:18 Warning PPPOE
07.07.2023 10:45:18 Warning DHCPC
  • July 11, 2023
And still going on intensely:
Date/Time Severity Module Message
11.07.2023 09:31:02 Warning PPPOE
11.07.2023 09:31:02 Warning DHCPC
10.07.2023 16:00:57 Warning PPPOE
10.07.2023 16:00:57 Warning DHCPC
10.07.2023 15:17:48 Warning PPPOE
10.07.2023 15:17:48 Warning DHCPC
10.07.2023 14:06:44 Error PPPOE
10.07.2023 14:06:42 Warning DHCPC
10.07.2023 14:06:42 Error PPPOE
10.07.2023 14:04:56 Warning PPPOE
10.07.2023 14:04:56 Warning DHCPC
08.07.2023 00:19:31 Warning PPPOE
08.07.2023 00:19:31 Warning DHCPC
Thomas van KPN
Hi @nrls, welcome back!
I've merged your topic as it's the same issue. Have you spoken to our colleagues at 0800-0402 about this?
They can take a look at your connection and make a ticket or send a technician if that's needed
  • July 11, 2023
Hey @Thomas I guess that line is only working in Dutch (which I cannot speak), so is it possible for you to create a ticket for me?
Bart van KPN
  • July 11, 2023
I created a ticket. My colleague will will call you within 3 working days to discuss further actions. Please let me know when you had contact.
