Can't send nummerbehoud SMS to 6688 from Lyca number
  • 19 februari 2023
  • 620 keer bekeken
good morning, since yesterday I chose a kpn subscription, but I can't send sms to the number 6688
I tried from another phone and it doesn't work, it says sending failed
Beste antwoord door IonutM
I solved it myself, this is the solution for Lyca:
If ou still can’t send/receive SMS please check the Message Centre Number (MCN) in your SMS settings – it should be +31684000111 for Lyca Mobile Netherlands. If you see a different number, enter +31684000111 and turn your handset off and on and re-try sending any unsent SMS. If the problem remains please contact .Thank you from tomorrow I will be a kpn customer:)
  • 28479 reacties
  • 19 februari 2023
Hi @IonutM, welcome! This is the sms for the transfer of your phone number (numerbehoud)? You receive an sms from us on the number you want to take with you to us. And you have to respond from that same number, otherwise it won't work.
Make sure that the phone you are trying to send the sms from is connected to a mobile network. And that is has enough texts/balance left to send the sms. You have seven days to respond to the sms, so you can try again.
If it continues to not work, we can use another way of validating, for that we need your customer number of your current provider. You can usually find this on your invoice, or in your personal digital environment.
  • 19 februari 2023
I received the transfer sms yesterday from kpn , today again, but I can't send the sms
  • 19 februari 2023
I want to mention that the number I want to keep is PrePay  for the last provider not  abonnement end my
current provider Is Lyca Mobile
  • 19 februari 2023
  • 28479 reacties
  • 19 februari 2023
Excellent! Good to hear you got it solved, @IonutM, and for sharing your solution. And welcome to KPN 💐
