Hoe kan ik meerdere port forwardings instellen op mijn Box 12? Krijg een melding over poortconflict
  • November 30, 2023
  • 1 reactie
  • 361 keer bekeken
I have several external devices that I want to add to my home network
For example: no real devices or IP addresses
Canada central FQDN device 1 20.201.84.235
Japan west FQDN device 2 135.91.19.122
The port forwarding rules I need are:
Outgoing TCP 443
Incoming UDP 3239
However, once I successfully add the first line, I get the message (Port Conflict) when I try to add the second line. How can I add multiple rules for many external devices with the same ports using the Experia 12 modem? I hope this makes sense.
1 reactie
Hi @Andy Sumpton : Please have a look at this knowledgebase article:
All information about portforwarding is documented there.Â
