No internet ! It's KPN's fault. Please fix now!
  • 24 januari 2025
  • 68 keer bekeken
Yesterday internet was there till 12AM after that is gone still now… ! and is total KPN fault !
2 reacties
Forum|alt.badge.img+12
  • 4335 reacties
  • 24 januari 2025
Then call KPN at the free number 0800-0402. 24/7 if you have no service at all
  • 6846 reacties
  • 27 januari 2025
Hi ​@Karolis700 this seems to be a problem with the connection in general. You should contact technical support directly so they can analyse the connection. I hope this issue will be resolved soon.
