Accessing locally hosted computer without opening DMZ
  • January 10, 2023
  • 202 keer bekeken
I have a query , If I want to host local server for private use on my network and want to access remotely via the static ip in the modem/ router , what option would you suggest to use from the router / modem.
I don't think DMZ is an option now . Ash
I want to understand, how can I use one of the methods without violating security protocols of KPN .
Beste antwoord door wjb
Never use DMZ to access a computer that is absolutely insecure.
Make sure the LAN IP address of your computer will not change by defining a DHCP reservation in the Experia/KPN Box.
Setup port-forwardings to the IP address of the PC for the ports you want to be able to access.
  • January 10, 2023
  • January 11, 2023
My Laptop is on Local static IP , I have reserved IP for this Mac address. Can I use following by creating Manual Rule ? Do you have any instruction to use this with security without exposing to probable security threats .
  • January 11, 2023
You can use the port-forwarding functionality.
Ofcourse you should only forward those ports needed to access the functionality you need on that PC.
I don't know what you want to achieve but if it is that you want to take over that computer through remote desktop than I would advise you to use a VPN connection to your home network and access the PC within that VPN connection instead of just forwarding the port for RDP to your PC.
  • January 11, 2023
I want to use webservice hosted on my laptop remotely .
  • January 11, 2023
Than just forward the port under which the webservice can be reached.
