Canon Pixma G3501 printer can not connect to KPN Box 12
  • jul. 10, 2023 6:37 a.m. UTC
  • 90 keer bekeken
Sorry for English only but I just arrived in the Netherlands.
My Canon G3501 printer will not connect to KPN modem/router.
Printer is configured with Wifi name and password.
KPN modem/router sees the printer MAC and logs record that it is attempting to connect but sending a bad password.
The printer supports WPA/WPA2 with TKIP or AES2 encryption.   I have set the passphrase to the Wi-fi passphrase several times.
I have other devices that have connected with the specified SSID and passphrase.
Q: Does the KPN Box 12b support WPA/WPA2 with TKIP or AES2 encryption?
Beste antwoord door Claudenw
After several attempts it has connected.
2 reacties
  • jul. 14, 2023 10:53 a.m. UTC
It should support those protocols Claud. Did you manage to connect the printer to the modem?
  • jul. 18, 2023 9:35 a.m. UTC
