Home assistant not reachable after update
  • 21 maart 2025
  • 8 reacties
  • 57 keer bekeken
Last weekend an update has been done after which I can’t connect to my home assistant anymore.
Can someone help me out with what has changed and what I need to do to get connected again. Cause none of my automations are working at the moment.
When using the app to connect I get the message :
No connection with the server possible
Beste antwoord door MartijnSteenhorst
The fresh install did work. Something some how got corrupted. Fresh install fixed it
8 reacties
AriënC
  • 2338 reacties
  • 21 maart 2025
Can you tell us more about your netwerk setup?
And what do you have updated?
I have the KPN Box 12. From here I am using a tp-link switch. At one of the poorts I have a Deco M4.
This Deco has its own Wifi name.
The strange thing is that when I connect to my deco’s wifi I get the “no connection with the server possible”
When I connect with the Wifi from KPN Box I get a ssl error
I haven’t updated anything. It was working till last weekend when I think KPN did some network things
I think it is due to home assistant being corrupt. I will do a fresh install during the weekend
bnh
  • 2327 reacties
  • 21 maart 2025
I have heard that there was indeed an unfortunate update in some cases.
How do you normally reach your HA system?
Normally via the app or when using browser by the default url.
Hope the fresh install will do the trick
Sanne van KPN
Forum|alt.badge.img+18
  • 7505 reacties
  • 23 maart 2025
Hi ​@MartijnSteenhorst and welcome to our KPN Community! How did the fresh install go, is the home assistant reachable now?
Sanne van KPN
Glad to hear it! Thanks for letting us know. 😄
