How can I set my own modem in Bridge Mode?
  • August 25, 2022
  • 1 reactie
  • 713 keer bekeken
dharm
Deelnemer
Hi team,
I am using my own Wifi router .  How can i set Modem to bridge mode
Beste antwoord door Anonymous
Hello @dharm
You can't, the KPN modems do not support bridge mode.
If double NAT is not a problem then you can set your Wifi router as DMZ device on the KPN router, then all traffic will be forwarded to your Wifi router.
To do that you'll have to make a DHCP binding for your Wifi router and then set it as DMZ device in de KPN modem.
Another possibility is to set your Wifi router in AP mode (if it supports that) so it won't function as a router anymore.
1 reactie
  • August 25, 2022
Hello @dharm
