How do I install a Netgear ORBI 50 on my KPN system?
  • April 10, 2020
  • 1 reactie
  • 1266 keer bekeken
Hi there, I have a NetGear RBK50 Orbi (mesh WiFi System, https://www.netgear.com/orbi/rbk50.aspx) that I would like to install and use as a router instead of the experia v10a. My subscription is internet only 200 mbs (Fiberglass). How shall I proceed?
thanks and best
Lorenzo
Beste antwoord door Susan_
Hi @lorenzopelle. welcome to our KPN Forum and thank you for your message!
Everything about installing your own router instead of the Experia Box can be found in these 2 topics (last one about the Fritzbox):
Gebruik een eigen router achter de Experia Box
Fritz!Box bij KPN
Otherwise I hope the community can help you out with this question!
1 reactie
Susan_
  • April 13, 2020
Fritz!Box bij KPN
