How to bypass KPN router and dial the connection from my OpnSense firewall?
  • mrt. 28, 2024 11:52 a.m. UTC
  • 204 keer bekeken
Hi all,
I just got the KPN box delivered. my contract is gigabit. I see that the kpn box (router) uses PPPoE to connect to KPN. I am trying to bypass kpn router and dial the connection from my OpnSense firewall. Unfortunately I can’t make it work. any guidance here?
Thank you
Beste antwoord door nikkon
I actually made it work. On my firewall :You need to create a vlan with the tag ID 6. Add the pppoe interface you are using to dial Kpn in that vlan then connect. Works like a charm.
Forum|alt.badge.img+28
  • mrt. 29, 2024 6:46 p.m. UTC
Hi @nikkon, welcome here.
I must admit that I don't really know how this exactly works. But, we do have a topic where experienced users might help with connecting your own router.
Would and could you please ask your question there?
  • mrt. 29, 2024 6:55 p.m. UTC
  • apr. 2, 2024 3:02 p.m. UTC
Great to hear, and thank you for your feedback.
