I cannot login to a certain IP, how do I whitelist it?
  • December 18, 2022
  • 93 keer bekeken
I cannot login to any site starting with *****************
  • December 18, 2022
Hello @p123
That's because that IP address is a private IP address, it cannot be reached from the internet.
It's strange that this is listed in a public dns server.
  • December 18, 2022
Yes, I actually use VPN to access it, but it does not work still, but when I connect my vodafone ziggo network in a frends house it works.
  • December 18, 2022
From the same PC/laptop?
If not, maybe the settings are not the same, DNS or Default GW?
You’re not using the same subnet in your own network?
Otherwise I see no reason it shouldn't work.
The VPN is connecting to that network?
  • December 18, 2022
It is the same PC, KPN network vs say vodafone hotspot/ziggo wifi, any cafe wifi. I have tried multiple times, only it does not work on KPN home wifi. Blocks my ease to work from home.
  • December 18, 2022
Maybe if you disable IPv6 in the modem or on the PC will get it working.
Â
