Is my GL-MT6000 AX6000 Flint 2 router supported by KPN?
  • June 4, 2024
  • 8 reacties
  • 435 keer bekeken
Hello… Sorry if my English is not great…
I have non KPN router “GL-MT6000 AX6000; Flint 2 router” https://www.gl-inet.com/products/gl-mt6000/
Is he supported to be used in KPN? Tv is not needed.
I can provide pictures of settings that can be set inside.
By default he try to connect but it never does.
Beste antwoord door TDN
@MatijaD Without KPN ITV you can use this router in WAN mode "PPPoE” and VLAN 6
8 reacties
Forum|alt.badge.img+12
  • June 4, 2024
  • June 5, 2024
User Name and/or Password i copy from experia router.
As i read around, the password is kpn or ppp. And some ppl says is not even needed?
The rest of data will automatic get when connection is establish?
Also, the VLAN ID? how do i get it or is it 6 liek on example ?
  • June 5, 2024
@MatijaD You can put anything in User/Password, they may not be empty. VLAN ID=6 is important.
  • June 5, 2024
Ok. got it working. Many thanks.
In IPv6 mode i have options: Native; Passtrough; NAT6; Static IPv6
For static I think im ok not to set. For the rest, is any option to select from them?
  • June 5, 2024
@MatijaD Native is OK
  • August 25, 2024
I get the message no cable detected. It worked before.
Just with Username password internet internet. Vlanid 6
Why does it suddenly stop working? This is so frustrating!
  • August 26, 2024
Well apparwntly my kid pulled out the fiber cable from the small device (before modem)
And thats why it didnt work... Lol
Lol. I'm glad you could resolve it Youness!
